Hi Guys,
I need some help again.
I have just purchased a 123 Electronic Dizzy for my 67
XKE. My workshop manual does not give the advance specs
for the stock dizzy.
Can anyone give me the specs, ie, 30* at 3000 rpm? Or even
better, what about the correct setting for the NEW 123
Dizzy?
Much appreciated.
Chris–
28 Model A Pickup,29 Chevy,67 XKE,68 250SL,74 MGB,83 911SC
In reply to a message from Floats sent Tue 22 Mar 2016:
I’m assuming that you have the standard 123 and not the 123
Tune dizzy. I used the 0 setting and the car starts and
runs so well, I haven’t bothered with trying another. As
you know, changing the curve on the is very easy once you’ve
removed the distributor from the block :>( OTOH, the 123
allows setting the curve via a laptop operated by a
passenger while the car is actually being driven.–
Mark 1E14988 67 OTS, 2002 VDP
Burke, VA, United States
In reply to a message from davidxk sent Tue 22 Mar 2016:
TKS Guys,
I don’t have access to the Jag service manual. All I have
is the Haynes manual. Please have a look and let me know
if you don’t mind and perhapse someone could suggest a
prelim setting for the 123 dizzy.
Sorry to be a nuisance.
Regards
Chris–
In reply to a message from mgordon sent Tue 22 Mar 2016:
Thanks gents,
OK great, I’ll start off with the initial setting at 0.
Thanks Drew, the info you sent is actually in the Haynes
manual. I did not even take a second look ( expecting to
be spoon fed) but it is all there. Thanks
Regards
Chris–
Mine is on preset 2 since I bought it. This is the geberic
GB6 version not the Jag version which wasn’t available
then.–
Pim van der Schaaf, 1E34261, 1A33630BW
Rotterdam, Netherlands
