Any tips on removing the oil pump drive shaft bushing. I
removed the 1/4’’ bolt from the front of the engine and
tried to tap out the bushing. Do I need to have
it ‘‘pressed’’ out, or get a bigger hammer?–
AJ11
In reply to a message from AJ11 sent Sat 7 Mar 2015:
It will come out with a hammer but you need to be really careful
you don’t damage it. We have a piece of round bar stock machined
up that fits perfectly into the bush to minimise damage.–
Andrew B. '67 S1 & S1.5 FHCs,'64 S1 OTS www.projectetype.com
Adelaide, Australia
Why are you taking it out? They rarely are so worn that they need
replacing and getting it back in to the exact same spot is so
important. A good machine shop can do almost any work on a block
with it still in.
Phil.–
PhilW
Virginville, Pa., United States
In reply to a message from PhilW sent Sun 8 Mar 2015:
I need to have the cylinder liners replaced and since the
bushing extends below the bottom of the block, it wouldn’t
sit properly on a work surface. I’m also still trying to
find a shop in SE Michigan that can replace the liners.–
AJ11
Talk to Chris at Holbrook Racing Engines or see if Roush is taking in any work.
Bob
889076
Plymouth, Mi.On Mar 8, 2015, at 12:00 PM, AJ11 ajacobson12@comcast.net wrote:
