I have recently acquired a 1969 series 2 OTS. I have
searched all of the usual places for an engine number (above
oil filter, top left side on bell housing flange, front of
head) to no avail. Does anyone have any suggestions where it
might be. The features of the engine look exactly correct
for month and year. Could this be a factory replacement
engine with no numbers - any advice appreciated.–
jwforden
In reply to a message from jwforden sent Tue 22 Apr 2014:
Engine numbers were not stsmped into heads from MY 1968.
The block will have a casting date on the intake side to
provide a clue. A few possibilities. A dealer replacement
block is one. Corrosion making the number hard to read
possibly another. If the engine is original, the engine
number will be stamped into the crankshaft flange and into
the edge of the flywheel. You can’t see the former absent
removing the sump but if you rotate the engine 180 degrees
from TDC you’ll probably be able to crawl beneath the car
and read the number through the covered peephole at the
bottom/front lip of the bell housing. If not there rotate
the engine gradually by degrees til you can see it. If no
number, then either a replacement flywheel or replacement
engine.–
Nick Saltarelli '68 Cdn mkt E-type S1� OTS, '54 XK120SE OTS
Niagara, Ontario, Canada
might be interesting to check the casting date on the side of the
block/ month day and year–
Steven Phelps 66E 2+2 69TR6 62 Norton Atlas
vero beach, fl, United States
sorry, left side in front of the dipstick hole and slightly below–
You’ve looked in all the correct places so suspect it is a factory
replacement motor. I had one such unmarked motor and have heard of
others. It should have been on the bell housing flange on your car.
pauls
<<<<<<<<<From: “jwforden” jeffwposton@hotmail.com
Subject: [E-Type] 4.2 series 2 no engine number
In reply to a message from paul spurlock sent Tue 22 Apr 2014:
Sorry Paul and Nick but the bell housing flange is possible
only in very late 69 cars. Jaguar issued Bulletin 1-A-13 on
1/15/1970 with the title of ‘‘Engine Number Locations’’
(sort of on point) which states in part that at the
following engine numbers the location has been revised to
the bell housing for easier access. ''The number is now
stamped on the crankcase bell housing flange on the LH side
adjacent to the oil dip stick.
XJ6 7L 5356
4.2 E type (Series II) 7R 6306
4.2 E type (Series II) 2+2 7R 38106
So a statement that all 1970 MY Series II cars would have
the number on the bell housing flange is accurate but for
1969 it is not.–
pauls
George Camp
Columbia SC, United States
The number will be stamped on the edge of the bellhousing flange on
the left side of the engine, behind the dipstick. It’s hard to see,
and gets covered in engine gunk. Clean thoroughly and you’ll find it.
In reply to a message from Michael Frank sent Wed 23 Apr 2014:
So if I grind off the numbers on my 85 XJ6 block in my 67 OTS
I can claim matching numbers, just like the other guys on
ebay? :)–
Mike Oldak 67 1 1/4 OTS
Bethesda, Maryland, United States
George,
IIRC it happened in July '69, nevertheless the OP had looked in all
the correct places for pre and post July '69 so looking for other
suggestions for which I had none. Someone else did suggest the
flywheel, I know they were on the earlier cars but thought that was
discontinued on later cars, am I wrong about that?
pauls
1/15/1970 with the title of '‘Engine Number Locations’'From: “George Camp” scjag@juno.com
Subject: Re: [E-Type] 4.2 series 2 no engine number
In reply to a message from Michael Oldak sent Wed 23 Apr 2014:
Mike, I don’t need them as my engine matches the data
plate…and always has. But this is indeed an interesting
and disturbing discussion…on Jag-Lovers, no less.–
Eric,
you can borrow them when I’m done with them!
Guess what, I just found that extremely rare, factory special
block in my OTS.
Eric
DFW Texas, United States
Many thanks for the helpful information - I’m not ready for
the set of stamps yet, I’ll keep looking.–
jwforden
In reply to a message from 64etype sent Wed 23 Apr 2014:
Eric,
E-type owners are a very disturbed bunch. Thats why I hang around
with them. I can not say how many keyboards I have lost due to ,
well stuff getting slopped on them ;-‘’(
Darrell
A true Loon E type–
block in my OTS.
