Cleaning out my cache of mostly E-Type and some other Jag parts. I thought I would offer them up here before listing on eBay or FB. Below is a list of what you see in the photos. Please reach out and private message me if you see something of interest. I will forward you additional photos and detailed description of any item(s) you are interested in along with price and shipping from Wilmington, NC.
- Set of Series l head light trim (excellent condition) SOLD
- Engine fan from Mark X 3.8 (very good condition, no bent blades)
- Mud shield from Series l E-Type (right side used condition) SOLD
- Air Injection rail from 4.2L Series lll (very good condition)
- Horn grills from S Type (very good condition, no dents or dings)
- Gear box rear mount with spring for Series l E-type (both new unused) SOLD
- (3) SU Carb tags matching set (used condition)
- SU Carb float (used condition)
- Rear panel pads for Series l FHC (original used condition)
- Set of window and door handles for Series I E-Type, XK 120, MK Series SOLD
- Right side exterior door handle for E-Type
- Fidanza light weight flywheel w/ new friction plate SOLD
- Clutch release bearing for 4.2L (in large white box new unused, unopened box)
- Clutch slave cylinder for Series l E-Type (in small white box-new unused unopened box)
- Header tank from Series lll (has been brazed and repair)
- SU fuel pump negative ground (not working)
- 3.8L Engine with internal parts from MK X (block was boiled, and cylinders honed)
- 3.8L head with corrosion on jackets (repairable)
- 4.2L head with cams (very good condition. I believe it came from an early XJ6 or Series ll E-Type)
- 3.8L Crank (Previous owner let sit in garage for years (not sure it’s salvageable)
- Series l E-type Amco bar (used, a little twisted with slight pitting)
- XJ6 Grill from Series lll (used but in very good condition)
- E-Type OTS 3-piece wood rear hood bow tacking set for convertible top (new unused condition)
- Set of four Series ll -lll wire wheels with 3 new original Dunlop tires that never it the pavement (very good condition)
Thanks - Kevin
910 616 8383
