[E-Type] Best way to remove old contact cement
I am renewing the top on my 61 OTS and there is a lot of old
contact cement on the header panel which will need to be
removed. I could grind most of it off, but there must be a
more elegant way. Will paint stripper work or ???
Larry–
'62 XKE OTS '64 XKE FHC
Agoura Hills, CA, United States
In reply to a message from LarryK sent Tue 6 Jan 2015:
Not sure how 3M adhesive remover would affect the tops
fabric, but it works very well on removing adhesives from
metal.
http://multimedia.3m.com/mws/media/224566O/adhesive-remover-
citrus-base.pdf–
Ralph, 1970 FHC, 1R27295
Coastal NJ, United States
Dear Larry,
Try rubbing a patch down with petrol or softening it with a hair
dryer.
kind regards
Marek–
v12 E-type running MS3/3X sequential lpg and petrol
In reply to a message from RGK sent Tue 6 Jan 2015:
Sometimes you can yank off hunks of it by pressing duct
tape on top of it then pulling it off again (like a hair
removal waxing - not that I really know what that is like).–
Geo Hahn 1969 OTS 4.2
Mt Lemmon, Arizona, United States
Goof off?
Joel–
ex jag, '66 E-type S1 4.2, '56 XK140dhc, '97 XJ-6
Denison, TX, United States
I used lacquer thinner and 3M scotchbrite pads. Messy, but worked.–
Nick Saltarelli '68 Cdn mkt E-type S1� OTS, '54 XK120SE OTS
Niagara, Ontario, Canada
In reply to a message from N�ck sent Tue 6 Jan 2015:
So what’s wrong with actual contact cement cleaner?
It’s always worked for me, and contrary to some of the other
suggestions here, it normally won’t harm paint or plastic.
My PVC hatch surround trim was covered in it but it all came
off just fine.–
Clive, '62 Coupe 860320
Ontario, Canada
Thanks for the suggestions. I had some old Aircraft Paint Remover on the shelf and decided to give it a try. It worked pretty well over the metal and cleans up with water. It took a couple of coats to remove the cement where is was built up. Still nasty stuff though.
Next Question, this one is HARDER. What should I used to clean the old contact cement off of the INSIDE of the Amco top material? I am fairly certain the the Aircraft Paint remover would destroy the top material in short order. I’d like to save the top as it is in excellent condition. I have no ideas on this one.
Larry--------------------------------------------
On Tue, 1/6/15, ex jag jcrprops@sbcglobal.net wrote:
Subject: Re: [E-Type] Best way to remove old contact cement.
To: e-type@jag-lovers.org
Date: Tuesday, January 6, 2015, 12:39 PM
Goof off?
Joel
3M General Purpose Adhesive Remover 08984. Works GREAT.
Doesn’t harm car finishes or fabric. I’ve used it for
years. http://tinyurl.com/8g8d75s--
Larry
Richard Cunningham 64 FHC http://www.xjjag.blogspot.com
Daphne, AL, United States
Thanks Clive,
I have never used contact cement cleaner. I’ll try it on a little spot and see if the top fabric holds up to it.
Date: Tuesday, January 6, 2015, 2:43 PM
In reply to a message from Níck sent
Tue 6 Jan 2015:
other
came
off just fine.
Ontario, Canada
In reply to a message from jkohler@sbcglobal.net sent Tue 6 Jan 2015:
I’ve used the 3M General Purpose Adhesive remover to clean
contact cement and even the black 3M Super Trim Adhesive off
of vinyl panels with no problem. In fact I was restoring a
panel on my original hardtop headliner and stripped off all
of the glue using the 3M remover without damaging it. It is
slow and painstaking because the glue adheres so well to the
fabric backing but it came off bit by bit.
And yes Aircraft Stripper is highly concentrated methylene
chloride. It will tear right through vinyl assuming that is
what your top is. I’d advise you to not go near it, nor
anywhere near your car really. That stuff is nasty. I
almost destroyed my hardtop by using it. I had to have a
shop that specializes in fiberglass repair apply new gel coat.–
Erica Madison Moss 64 3.8 OTS
Austin,TX, United States
Thanks for the suggestions. I am going to try the 3M contact cement remover and see how it goes.
On Wed, 1/7/15, Erica Moss erica.m.moss@hotmail.com wrote:
Subject: Re: [E-Type] Best way to remove old contact cement from #inside# of Amco top material.
Date: Wednesday, January 7, 2015, 3:40 PM
In reply to a message from @JKOHLER
off
restoring a
It is
the
that is
nor
nasty. I
a
coat.
