In reply to a message from John M Holmes sent Sun 23 Jan 2011:
Thanks, John … I’d seen that a while back, and I must say
it is not the clearest DIY I’ve read - he talks a lot about
using shims, adding or subtracting them, but not about where
the shims go! So, for a noob like me, it’s baffling. Also
it’s alarming when he starts talking about cutting and
welding !!!
I started with the easiest option - loosen some of the bolts
at the rear of the bonnet so that I could move the wings in
and out a tad on each side, but couldn’t get enough
adjustment. Now I will try the hinge bolts as suggested.
This involved turning the car around in my garage - I fired
it up and it started immediately, which made me happy as it
has been sitting for over a month while I’ve been fitting
reverse lights, re-wiring, refurbishing dash/console,
fitting new radio speakers, new battery cables, etc…
Now it’s in a position where I can get to the bonnet hinge
bolts, so will report back after I’ve tried their adjustment.–
In reply to a message from jjbunn sent Sat 22 Jan 2011:
Julian, It would appear that you are bout to embark upon an
excursion into the delicacies of bonnet alignment. Suggest
you read the following, before you get too far with this!
http://www.xke-lovers.com/bonnet.htm
Julian, '69 E-Type 2+2
Pasadena, United States
