I just returned from a 2,500 mile trip down to Daytona Beach FL and
back to Brooklyn in my 1955 Sunbeam Alpine. I was attending the
Sunbeam United there and one of the events they had for us was a
visit to Crane Cams. It was a really interesting tour of their
facility and at the end just after we visited their R & D dept. we
had a question and answer session. The topic of the new oils came
up. They acknowledge that they have had a great increase in failures
of new cams since the ZDDP has been removed. They said that so far
they have covered all under their warranty, but have cut open and
analyzed the damaged cam lobes. They said that in all cases the
damage was not caused by a soft cam lobe but rather by the inability
of the new oils to help induce the rotation of the tappet during the
break in period. They said they there is a minute angle ground into
the face of the came lobe as well as a really minute conical grind
to the top of the tappet. The reason for these shapes is that the
cam will then rotate the tappet slightly on each pass. The new oil
without the additive is actually more slippery than when it had the
ZDDP and it has lost the ability to properly rotate the tappets.
They say that the long term result on a older engine has yet to be
determined but it definitely is a very serious problem with the
installation of a new cam. They had two brands of break in oil they
recommend to all their customers which were formulated with enough of
the ZCCP additive to be effective for break in of a new motor. Since
their focus was their cams we didn’t discuss other break in parts
like the rings seating or the bearing surfaces burnishing in. I am
going to call them to get the ordering information for these break
in oils as my motor rebuild is almost complete at Terry Lippincott’s,
although with its original cams and so perhaps not a problem.
Dave Reina
67 ots
