Has anybody experience or already thought of installing a “add-on fused
circuit panel” , in fact a fused box with maxi-flat connectors in a nice
plastic box exactly like we have in our daily cars ?
Advantage :
easy and proven installation under the dash.
available cheap ( new around 15 to 30 USD ) .
installation out of sight .
improves safety as to fire hazard.
protects electronic/electric equipment for overvoltage.
I think this is a nice winter project so anybody this side of the pont ,
give a shout in case you want to know more.
In reply to a message from Walter Luysterborg sent Sun 10 Sep 2006:
A couple of days ago, my fans stopped working. A loose fuse holder
was the problem, getting the end of the fuse so hot, it melted the
wire inside the fuse. Since I has a show to go to the next day, I
used an inline AGC fuse holder with ring terminals on the wires. In
the fuse holder, there is a hole on each side that is perfect for a #6 sheet metal screw. I attached the ring terminals to each side of
the fuse holder and stuck in a 25a AGC fuse. It worked so well and
was so easy, I just might do it to the other high-load fuses. It
doesn’t look pretty, but I’m the only one to look behind the dash.
Jim–
Jim Ashworth S2 OTS-finally being driven
Canterbury, NH, United States
Walt,
Brand new authentic fuse blocks are available for $12, so for $48
you can eliminate any fuse issues for the next couple decades.
Timewise, I’d think you would still be re-routing the wires to an
aftermarket fuse block in the time it would take to R&R the new
fuse blocks. Then there’s the wire ends…
I had the same fuse/fan issue as you did, put all new fuse holders
in and all my intermittant ‘E’ problems disappeared. I spent more
time trying to make the old ones work than putting new ones in.
FWIW.
Dave–
1969 BRG OTS
Skaneateles, NY, United States
You can buy an ATC fuse block for a few bucks, may as well do it
right and replace the Lucas blocks. Painless Wiring has a good selection.
Mike Frank
Have ordered a few as well as add-on fuse circuit panel from JC
Whitney,they are only 18 to 24 USD.
I think it is safer and better to avoid problems electrical in this
case ) and install a fuse here and there.
Walter
64OTS+69IIFHC
Correction. Make that an ATC in-line fuse holder. The one for the
newer flat fuses.
Jim
