In reply to a message from davidxk sent Wed 16 Jul 2014:
Me neither, but X happening and X being attributable to Y,
are two different concepts.
The first half dozen motorbikes I had as a kid were non-
runners when I got them. I knew enough to clean out the
carbs and set the points etc and decoke them. Memory from
45 years ago may be playing tricks, but those vehicles and
a long string of dozens of later purchases commonly had
gunked-up carbs, lines and pretty much everything else.
Rubber lines were often cracked, plastic clear ones had
shrunken and gone hard, o-rings were often perished and
alloy float chambers and even brass jets were
gummed/scaled or corroded depending on circumstances. All
of that happened before anyone thought of putting ethanol
in road fuel.
I’m not saying fuel systems don’t get problems today, but
I am saying that the occurence of fuel system problems
with 10% ethanol does not seem to have changed very much
in my anecdotal experience. The latest was a Honda-powered
cement mixer that last ran in about 2009 and sure enough
it didn’t want to start a few weeks ago. It had only ever
had alcohol fuel in my ownership (c10 yrs?) and was of
course bone dry. I cleaned the carb the usual way (noted
the typical white powdery residue one sees with alcohol
fuels) and it started right up.
I normally have a range of vehicles or small engines that
are over-wintered and I always mean to buy fuel stabiliser
but have never actually got round to it. So far, my stuff
has started up next season without problems and the last
two years I’ve lived in a very humid climate. The cement
mixer used to be fine as well but 4-5 years is asking for
trouble. Maybe I’m living on borrowed time or maybe next
year will be the same as this.
I have, on the other hand, occasionally put a half litre
or 250 ml of pharmacy alcohol in tanks that have somehow
got water inside and I’ve done that to get rid of the
water by helping it mix with fuel and pass through the
engine.
But do I want 15% or more alcohol gasoline? No way.
Pete–
However, I’m not inclined to believe that everyone else who
has had problems is deluded. I can only assume that other
factors (particularly the low humidity in most of CA), and
1E75339 66 D, 1R27190 70 FHC,
Gaithersburg, Maryland, United States
