Chris,
I’ve been away from the forum for a coupla days so apologize if you’ve
tested these things but your car has a starter relay and a starter
solenoid. Do you know the relay is working? When you say the starter
spins, I assume you mean it cranks the motor? If the starter motor
spins without cranking the solenoid is not energizing.
pauls 67ots
In reply to a message from db7gtgrigio sent Sun 1 Jul 2012:
AAARRRGGGHHHH!!!
this is killing me!
There is 12v at the top solenoid terminal from the battery.
verified with test lamp.
I removed the copper strap between Solenoid lower terminal and
starter. Cleaned up the strap, cleaned up the screw terminals,
cleaned up the nuts, used copper ease and tightened everything up.
Starter spins when 12v applied to input terminal on stater case.
How come when I short out the upper and lower solenoid terminals I
get nothing? Not even a tint spark. Surely this is giving direct
12v feed to the starter and it should spin.
What on earth is going on…???
<<<<<<<<<<From: “db7gtgrigio” christophera@fastmail.com.au
Subject: Re: [E-Type] Click, nothing. Click, nothing
