In reply to a message from Angus Moss sent Tue 11 Jun 2013:
Dear Angus,
If it is like the s3, then I think the big nylon gear wheel needs
to be swapped over. This has a cutout in it where a microswitch
contact closes the parking contacts. If you have one with the
words ‘‘Park 100’’ stamped onto it, then you’ll be looking for one
with ‘‘Park 280’’ on the cover.
kind regards
Marek–
MarekH
In reply to a message from MarekH sent Tue 11 Jun 2013:
It’s a very simple change - just turn the link on the end of the
motor round 180 degrees.–
'69 Series 2 2+2
Hertford, United Kingdom
In reply to a message from Tim Roberts sent Tue 11 Jun 2013:
I should have said: it’s a simple task once you’ve got the assembly
out of the car!–
'69 Series 2 2+2
Thanks guys. Seems much easier than the S1 then! I
can’t move the crank through 180 as I don’t know the
original position of it! Can’t remove the link either
because (so I’ve read) that if you reposition the link
AND the crank is in the wrong position, it cancels out
the change. Guess I’ll just have to fire it up and see
where it parks!–
65 OTS 1E11497 www.mossjaguar.com
Just reviving this old message.
Is this the link your referring to that needs to be turned 180 degrees, to park the wiper blades on the right hand side, is this all that needs to be done.
