Can anyone please provide me with an exhaustive parts list
for converting my S1.5 FHC to RHD?–
1968 S1.5 FHC
In reply to a message from 600 sent Wed 7 Sep 2011:
Also, the dashboard wiring loom will be different, the
speedo cable is different, the throttle linkage and gas
pedal assembly are different, the dashboard indicator strip
(because the switch’s position will be reversed), under-dash
aluminum panels etc. etc.–
Clive, '62 Coupe 860320
Ontario, Canada
In reply to a message from abowie sent Wed 7 Sep 2011:
Rack assy C24530
Column cover BD19714
Accel pedal Housing C17844
Accel pedal C20223
Accel pedal pad C3473
RH facia panel BD19644
LH facia panel BD19643
LH cubby box BD19699
If your car has the cubby lid then you will need the following
LH cubby box BD27499
Lid BD28260
Lid insert BD28260/1
Speedo cable C24878
You will need to extend the wiring for the instrument cluster and
switches, bend the clutch and brake pedals to suit.
Those are the major items. If you need any more help do not
hesitate to contact me offline.–
850225/679,1E21003,2W2001BW,JNAEY3AC100218,SAJNV4841KC156072
HEIDELBERG HEIGHTS, Australia
In reply to a message from 600 sent Thu 8 Sep 2011:
Pat,
This thread could run and run. If the car in question has the seat
belt warning system and you still want to use it in rhd guise, then
you’ll want to swap/rewire the passenger and driver seat and
seatbelt connections as they perform subtly different functions.
If this runs to April 1st next, remember to swap over the left and
right indicator wiring front and rear…
kind regards
Marek–
MarekH
