[E-Type] Difference between Series 1 and Series 2 Header
The headers and exhaust have been ripped from my car by an hump in
a service station forecourt whilst approx 400 miles from home and
so I am presently stuck in the middle of woop.
The Australian Series 2 cars had none of the anti-smog stuff that
the US cars had and are identical to the Uk cars.
Anyhow. I have access to a Series 2 header. Are they different to
that of a Series 1?–
Stephen 67 Series 1 2+2
The headers should be interchangeable.>From: “Stephen Pierce” sscpierc@bigpond.net.au
Reply-To: e-type@jag-lovers.org
Subject: [E-Type] Difference between Series 1 and Series 2 Header
Date: Thu, 4 Dec 2003 06:51:45 +0100
that of a Series 1?
Don�t worry if your Inbox will max out while you are enjoying the holidays.
Get MSN Extra Storage! http://join.msn.com/?PAGE=features/es
The answer to your question is, there is no difference. Even if the
manifolds had the S2 pollution control stuff, they could be used
interchangeably. Now, my question, where or what is woop?
I’ll vote for any candidate who promises to remove speed bumps…
Mike Frank
In reply to a message from Stephen Pierce sent Thu 4 Dec 2003:
The exhaust manifolds for the series 2 differed from serie 1
in that they had threaded bosses to hold the exhaust heat
shield that series 1’s did not have. The reproduction
manifolds are of the seies 1 type, they will fit the series
2 but the heat shield will have no attachment.–
R67cat
In reply to a message from Mike Frank sent Thu 4 Dec 2003:
Woop is the middle of nowhere. You know the place half way between
home and any place that can actually help you with the problem.
The place with no mechanic, no towing service and the only
accomodation has no running water and only has electricity on
Wednesdays.
The kind of place that if it was hit by a violent storm it would do
$2 million worth of improvement.
The place 200km west of the end of the earth.
Speed humps? It would be lucky to have road other than the highway
that runs through the middle of it. The only speed humps are the
slow moving locals!
I have got the headers and exhaust mounts sent to me by courier so
I should be underway today. Thanks for the feedback.–
In reply to a message from Stephen Pierce sent Fri 5 Dec 2003:
Mike,
What happened that your headers have to be replaced? Sounds serious.
Richard Liggitt–
'70 E Roadster, '98 XK8 Roadster, '02 Mini Cooper
Stephen,
That sounds like where I live :slight_smile:
pauls 67ots
Wednesdays.
slow moving locals!
Subscription changes - http://www.jag-lovers.com/cgi-bin/majordomoFrom: “Stephen Pierce” sscpierc@bigpond.net.au
Subject: Re: [E-Type] Difference between Series 1 and Series 2 Header
Speed Hump: (a) when you are on a hot date and have
limited time or (b) thing designed by wicked road
engineers to facilitate, at least every two or three
years, the replacement of one’s E-Type’s stainless
steel exhaust system thereby rendering useless the
lifetime guarantee
Ray Sharp
'61FHC
'71s2OTS.
Series 2 Header
------ snip-----
the highway that runs through the middle of it. The
only speed humps are the slow moving locals!..
----snip
