on my �66 S1 2+2 (separate locks!) I found that the driver
�s door lock is loose. I can rotate it by some 30 degs left
and right.
It has those tongue-like springs inside, but they look a
bit short cause they do not press it against the door sheet
metal anymore. The is no insert nor rubber under the lock
body, so I cannot adjust anything (I think).
It works nice, else, just it is so loose.
What can I do ? Make a small metal piece to put it under
the lock, inside the door, to better engage the tongue
blades and glue this to the inside of the door ?
Carsten–
Restoration in progress: 1966 2+2 LHD manual
Goettingen, Germany
