The following is a compilation of errors I’ve discovered in
12 years of E-Type Series 3 ownership, restoration, and
repair. It is in no way all of what may be wrong or
questionable, but is mainly to save you time and pause to
verify things when working on your car…all so we can
drive them more! Most of my knowledge is relative to the 2+2
but also applies to the OTS. Any OTS specific additions
would be great. My Parts Book references are the Series 3
2+2 FHC RTC9015 Feb 1974, but can also be found in the
alternate pages of the OTS book. Why British Leyland didn’t
keep the same page numbers between the 2 books I’ll never
know! Remember that the parts books were not reassembly
manuals, only reference for the parts techs at he dealers.
Since we don’t have true assembly manuals for the E-Types,
we tend to use them as bible. Beware! Even the ROMs can be
wrong too.
Please add to this thread if you know of something wrong or
questionable. I am volunteering to research, diagnose,
investigate, and document this information. If we discover
errors in the errata, let’s work together to try to solve
it. I will assign index numbers to each note to keep
tracking easy. They’re not in any specific order, but can be
categorized later in my document. When you add something,
increment the number, or reference an earlier index number.
One more note. I have to add a disclaimer(argh!). This is
for information purposes only and the users of this
information must be aware it could be wrong. Use it at your
own risk/pleasure. Sorry but I had to add this.
Here goes:
1 - RTC9015 p31.48 ‘‘Master Cylinder - Reaction Valve’’
Exploded view of internals(bottom of page) wrong. Also shown
wrong in ROM rebuild section. The 10878 ‘‘plastic seal
retainer cup’’ and ‘‘NSS’’ seal are shown incorrectly. The open
lip of the seal and cup must face inwards to maintain fluid
pressure. I will add a diagram in the document. I will also
add a diagram of the reaction valve internals as none exist.
Assembly is not obvious and can be assembled backwards.
2 - RTC9015 p31.27 ‘‘Front Suspension-Lower Wishbone’’ Lower
right in diagram, C15376 - 4 off big washers. There are only
2 total, 1 per side.
3 - RTC9015 p31.29 ‘‘Front Suspension’’ Lower right in
diagram, 8 UFB.131/8R bolts upside down. Nuts are on the
outside.
4 - RTC9015 p31.64 & p31.66 ‘‘Power Steering Unit’’ Note only
the RHD version is shown, not LHD. Same error in ROM rebuild
section. Pressure pipes (12711-short, & 12712-long) are
shown going to the pinion valve incorrectly. Should be: The
short pipe must go to bottom hole pictured in pinion
valve(i.e. when on car the forward hole). The long pipe in
the hole towards steering wheel). If these get reversed,
steering will ‘‘hard lock’’ by itself if you try to turn
steering wheel, possibly causing serious injury to your
body. (Don’t ask how I know this!)
…to be continued. Used too many characters for one post.–
Rich Mozzetta 1972 SIII V12 2+2
Sunapee, NH, United States
