Hi List, The pistons from my 69 ots has compression rings that are frozen in
place from sitting for twenty some years. I soaked them in kerosene for the
last week, to no avail. Is there a tool or some other way to free them
without damage to the piston? Any ideas or tips?
Lou Burkhardt
69 XKE
85 XJ6
74 TR6
I wonder if you lay the piston on its side and tap the ring where it
is split, on the end, with a small hammer/punch.
Interesting though… as a kid working in a garage on Saturdays snd
Summers, my boss always told me to take the rings off without breaking
them, just in case I broke one of the new ones putting them on. Then I
could use an old one in it’s place. The first couple engines I did, I
broke rings taking them off. But have never broken one since. Never
broke one assembling either. There is a kind of knack to getting them
off/on.
LLoyd -caretaker of PrtyKty-
Jaguar6703@aol.com wrote:>
Are the pistons still in the motor, or have they been removed from the block?
I had a piston that was stuck in the block from sitting a similar amount of
time with the spark plug out, and water sat on top of the piston for 20
years. I has to get the machine shop to press it out, and then had to
resleeve the block. Expensive! When I got the pistons out, the rings were
stick due to mineral deposits from the water. You could try soaking the
piston in a mild acid, such as vinegar, or Kodak indicator stop bath
(available from photo supply houses) to dissolve the minerals. However, if
it is just a carbon build up, I don’t know what might loosen them. Perhaps
try laquer thinner, as it is an excellent degreaser. Just protect yourself,
as some of the components in thinner are nasty.
Craig
At 12:17 PM 17/01/00 EST, you wrote:>Hi List, The pistons from my 69 ots has compression rings that are frozen in
