Hello Mike,
Having two master cylinders does not equate with
redundancy as you describe it. Each system has
to be able to perform the job individually. That is
clearly not the case as you describe it. That is
not a redundant system.
A redundant fuel pump fuel would have to have check valves
arranged in such a fashion that both pumps can run, or
only one of the two and you would not notice the difference.
Two pumps in series would probably not meet that condition.
But two in parallel with each a check valve at the end forming
an OR gate would do. You still have to have supervisory to tell
you that both are working or that one has died so you can
replace it quickly and maintain redundancy. So, Ray, the
system you describe does not meet the definition of redundancy
if both pumps must be working for the car to be able to run.
As with Mike’s master cylinders, two does not mean redundancy.
It is all in the arrangement.
The XJ-6 fuel supply was mentioned. Technically that is not a
redundant system, because both share the same switch. And
it is the switch that often fails. It also requires operator intervention,
while a true redundant system is fully autonomous.
Yes, Eric, the ultimate redundancy is the have two E-types,
just like any other Jaguar. One for driving, one under repair…
Dick Vandermeyden
San Carlos, California
