Hello Friends,
This is an on-topic question for an off-topic car; Specifically, my
new MG TD project.
The tank on my car has a lot of surface rust on the outside, and a
little on the inside, BUT the metal is still strong. I will be
refinishing the exterior of the tank as it remains visible on the TD,
and I will chemically de-rust the inside of the tank, after which it
will get a slosh-coating of sealant. The product I am using is from
Moss Motors and is designed specifically for fuel tanks AND alcohol
polluted gasoline. (Read a little disgust into the last few words
there…)
I write to ask if any of you have had problems with these kinds of
products. Please keep in mind that the TD is REALLY primitive. It
doesn’t even have a fuel level gauge, just a float that tells the
driver, via a light, that a couple of gallons remain in the tank! So
except for the inlet, the hole for the sensor and the outlet, that’s
it. Otherwise, its a metal can. New tanks are $1300+ before shipping
so the $50 bladder solution is appealing, especially since the
integrity of the tank is still viable. Advice encouraged - and
appreciated.
best,
rick lindsay / '73 E-type, and other cars______________________________________________________
