OK everybody, show of hands…
Raise your hand if you ever took the cap off the distributer, worked on it, put the cap back on and couldn’t start it because you left the rotor off.
Ahhhhh, yes.
Now I feel better.
Excuse me, I have to go back out to the garage now.
LLoyd–
Insofar as mathematics applies to
reality it is not certain, and
so far as mathematics is certain
it does not apply to reality.
Einstein
In reply to a message from JagWaugh sent Tue 4 Apr 2006:
Can I join the club if I was smart enough to put the rotor back on
but I put it on wrong and shattered the cap when I turned the
engine over?
P.–
Peter J. Smith, 1966 3.8S, 67 MGB
carson city nevada, United States
Never left the rotor off, but it usually takes me two attempts to
get the insulators in the right order whenever I fit new points.
Alan–
Alan 1970 2+2
Riverside ca, United States
I for one, would be glad to accept you as an honorary member.
LLoyd–
Einstein
I personally think he should go to the head of this very large class.
While that error is more obvious it is no less frustrating since a new
cap is now in order (or is that on order?).
Brian 66FHC
ICan I join the club if I was smart enough to put the rotor back on
engine over?
Hi Lloyd, I won’t put my hand up for that, but I have driven
around the block in my SIII with only the A bank plug wires
on.The reason for the bad engine performance was soon apparent.–
John M Holmes 1973 E Type SIII Supra 5-Speed, 1970 SII OTS
Sarnia, Ontario, Canada
Done that.
Gotya one better: I was just finishing up doing all the tin on a
Bug engine and looked over at the bench. Sitting there was the
slinger ring.
For those of you who aren’t sure why this would be a bad thing,
email me offlist and I’ll painfully describe why it WAS!! LLoyd,
I woulda drowned myself in some of Schmedley’s A-B soup at that
very moment…–
Ahhhhh, yes.
Now I feel better.
Paul Wigton, '60 DKW 1000SP, '55 DKW Sonderklasse, Tweety!
Keenesburg, CO, United States
heh… I once went about a quarter mile down my street with one plug
wire un-done. Boy did I feel stupid.–
–chuck goolsbee
65ots, 1E10715
arlington, wa, usa http://chuck.goolsbee.org
Does coming off ‘ramps’ and hitting the bottom of your car count? I
jacked the car up to get them under the rear tires, didn’t want to go
through the hassle of using the jack to take it down so measured the
clearance, with an inch or so to spare just didn’t count on it
bouncing a bit as it rolled down to the floor. OUCH! ;-(
Ly… er Joe, yeah that’s it, Joe Schmedly (with apology’s to the
other J. Schmedly on the list)On Apr 4, 2006, at 3:35 PM, chuck goolsbee wrote:
plug wire un-done. Boy did I feel stupid.
I started my 260Z once to set the carbs by reaching through the drivers
window. Damned thing was in reverse and dragged me into the street
before I could shut the key off.
Still got the scars on my left knee to remind me. ;-(
…that’s gotta be one of the most painful things I’ve heard!!
I was helping a friend rebuild an engine one time, Ford v-8, when we got the intake manifold on, ready to drop the carb on, he dropped a lock washer down the manifold hole.
Ended up having to pull a head (we guessed the right one though). But still not as bad as finding a slinger ring…
LLoyd–
Einstein
-------------- Original message ----------------------
In reply to a message from @soothsayer1 sent Tue 4 Apr 2006:
Done that.
slinger ring.
very moment…
Lloyd,
You must not have eaten your AB soup!!! Don’t recall having done that but have placed the wire for the points at the wrong side of the insulator.
pauls 67ots
Ahhhhh, yes.
Now I feel better.
LLoyd
…what a picture this leaves in my mind…
LLoyd–
Einstein
I was riding home once from university on my newly-built 650
Triumph Tiger. Doing a 160 mile fully-laden trip as your shakedown
run is not advised BTW, but I was only 19.
Anyway the thing wasn’t happy so I stopped on a small gravel pull-
over just before a bend along the two-lane winding A49 near
Hereford if anyone knows it, with big wagons lumbering past every
few seconds…
Took the carb top off, pulled out the slide, adjusted the needle
and replaced carb top, not realising I had trapped the cable
slightly and the throttle was now about 1/3 way open…
Big tall bike, student luggage tied to the tank and the back of the
seat, small gap for me to climb on and perch between the two
bundles. So I reach over to the left side, grope for the
innaccessible switch and jump on the kickstart. The bike bursts
into life and immediately reaches top revs in neutral. Five seconds
of this and my tight rebuild will probably seize or spit expensive
parts out of the crankcase, so I pull the clutch in and stomp into
second gear to stall it.
Of course it doesn’t stall and I have no option but to jump on
board side-saddle and fly out into the road with no time to check
for trucks… Lord be praised we do the mother of all drag starts,
around a sharp bend for good measure, but miss traffic and I manage
to retain control enough to climb over into a proper seating
position and reach down for the ignition switch behind my left knee.
Don’t think my heart has ever beaten so fast since… And now I
always snap the throttle open and shut after any carb work on any
vehicle before starting it up.–
Peter Crespin 66 2+2 ‘E’
Buxton, United Kingdom
David, that’s just the South American contingency. And as I recall, drinking it was the only way to get out of the club.
LLoyd–
Einstein
LLoyd,
Do we have to drink the asparagus-beet kool-aid to join this club?
