[E-Type] Heated rear window repair
On my wifes car the spade connector has come off the element on the
heated rear window,is there some kind of conductive glue available
to repairs this?
Thanks Gerry Ireland 878269 Ontario Canada–
gez
In reply to a message from gez sent Fri 29 Feb 2008:
have you checked out crappy tire. They should have something–
to repairs this?
Sunney
In reply to a message from Sunney sent Sat 1 Mar 2008:
Thanks Sunney will give crappy tire a try.
Regards Gerry–
to repairs this?
gez
G’Day Sunney,
In local parts shops here (Perth) they sell a small tube of brown conductive
paint liquid that has a little paint brush in the cap for repairing gaps in
demister lines. You just cut off the loose hanging bits each side of the
break, scratch the surface of the original lines a bit and then paint a new
path across the gap. Only cost a couple of dollars and worked ok for me. I
am sure if you try a local place near you they will carry this kind of
product. A bit hard to get a neat even thin line like the original with my
fat fingers.
Cheers, John B, 67 2+2 in Oz______________________________________________________
While there are conductive adhesives around, it might be a
lot easier to find some super-glue and the conductive paint
that has been mentioned. Clean the glass and conductive
surface (be gentle here) and glue the connector to the
glass. Then apply a good amount of the conductive paint from
the connector to the pattern on the window. It is probably
best to do this in a few coats rather than in one that might
drip or run. It is important that the connection to the
resistive element on the glass be good or it will fail due
to the high resistance heating up. Pick an adhesive for use
on glass, maybe ‘‘rear view mirror’’ adhesive will be best.
Good luck.
Mike–
to repairs this?
Mike Form
Southborough, Massachusetts, United States
In reply to a message from Mike Form sent Sat 1 Mar 2008:
Hi Gerry,
Our local shop sells Bison Elektro. Quite expensive though at about
19 Euro’s for a small three grams tube. But works well. I have used
it to fix the rear window haeting on my xj-6. Try a local
electronics supplier, those guys used it to repair printed circuit
boards.
Greetz, Eric–
EricV
Maastricht, Netherlands
In reply to a message from EricV sent Sat 1 Mar 2008:
Thanks to all of you for the advice, will have go at this as soon
as the weather warms up ,long winter this year.
Regards Gerry–
gez
