Call it beginners luck but I have been have initial success
forming bubble flares on Cunifer lines as I fabricate remote
bleeders during the rebuild of my irs. I have purchased a
stainless flex line to connect to the 3-way on the irs cage.
Here’s my question: It looks to me like the stainless flex
line fitting is a male ‘‘bubble’’ type fitting but the
original 3-way looks like it needs to receive a double
flare. Can anyone confirm this and if so what’s the best
resolution? Is there an adaptor of some kind (i.e. bubble
female to double flare male) or do I find a new 3-way to mount?
Thanks again for the help!–
Craig Gilbert - '68 E-Type FHC - RIP
Birmingham, AL, United States
In reply to a message from Craig_G sent Fri 31 May 2013:
Craig, On my SII’‘E’’ IRS the 3 way connector was clearly
double flare ( df ), and all the lines to it were also df
including the flex line from the car body to to the IRS. I
think you should consider getting a compatible flex line
rather than considering adapters ( which I have never seen !
). In a general sense I have never caught on to the usage
pattern of Jaguar re double bubble ( db ) and df…other
than to notice that no line ever had a db at each end …only
one. I have always use steel lines, and I gave up on making
the bubble myself. I always used long commercial db lines
which I the cut to length and put a df at the other end. The
db might be easier to make using the CuNi alloy tubing, and
i wish I had considered this option somewhat more carefully.–
John M Holmes 1973 E Type SIII Supra 5Sp, 70 SII OTS 05XJ8L
Ontario, Canada
In reply to a message from John M Holmes sent Sat 1 Jun 2013:
Craig, John,
I’ve also had luck making doubles flares with CuNi pipe even
with a cheap flare-making kit. However, my luck ran out on my
latest job ( replacing the clutch master & slave cylinders on
my '61 FHC) when I tried to use the standard metal pipe.
All of the existing connections were double flares. There is a
good writeup on flares and a pretty complete range of
hydraulic fittings and Cuni pipe at http://www.fedhillusa.com
I was able to make excellent double flares after doing some
research for a better tool than the typical yoke-style cheap
kit. I didn’t want to spend $$ and found this tool, which
makes really good flares:
CAL164 CalVan Tools 164 SAE In-line Flaring Tool Set
I bought mine from http://www.denlorstools.com It cost
$32.13 + s/h.
BTW, I completed the job, bled the system but had a leak at
the master cylinder out line. No matter how tight I made the
fitting - even after making several new pieces of pieces with
excellent flares. I have concluded that the new master
cylinder is defective ( bought from one of the ‘‘biggies’’).
I have now got an original Jag part on order from another
vendor. I’m $75 out ( too late to send it back ), but what
really p*sses me off is all the work I have to do again. What
the *&%! is wrong with parts these days!!!
Ray–
I wish I had considered this option somewhat more carefully.
Ray Sharp… '61 E Coupe & '71 Series2 E OTS
Montclair/NJ, United States
Cunifer pipe is the only way to go. Much easier to work with than the steel or
SS lines. JMHO
Larry----- Original Message ----
To: e-type@jag-lovers.org
Sent: Sat, June 1, 2013 4:56:58 AM
Subject: Re: [E-Type] Hydraulic Brake Fittings
Ontario, Canada
Thanks all for the replies. Good info that there is never a
bubble on both ends. I take it that since the caliper
receives a bubble then the original 3-way fitting on the irs
cage must be a double flare. Since my source for the flex
line (one of the usuals) has the 3-ways in stock with bubble
ports it looks like the easiest course is to order that fitting.
Keeping my fingers crossed for a positive result on the
pressure test.
Thanks again!–
SS lines. JMHO
