I’m pretty sure that your car will have TWO oil pressure senders.
One for the idiot light and one for the gauge. They should be on the
right side of the motor, have a look.
OK, took a look tonight, and here is what I found:
There is only ONE oil pressure sender, above the oil filter. It does
have two leads though. The rear (firewall side) lead is attached to a
same/similar brown/purple wire that appears on the “ignition light”
wire in the speedo (and also appears on the alternator). The “front”
(radiator side) lead is connected to a black wire. BOTH of the wires
go up from the top of the sender and come together in the fabric wire
harness wrap just above the oil filter and head forward towards the
distributor on a frame rail.
I can take photos if anyone needs a clearer picture.
“Real” work kept me busy until after midnight, so I have not had a
chance to fire up the engine to try other tests or observations.
If this were a network (an environment I am familiar with) I would
pull the “sender” & “alternator” end of the wire(s) and send a tone
down it, and probe/listen the far (speedo) side of the wire to see
which (brown/purple) wire actually goes to the speedo/light. I have
no idea if that is correct procedure with electrical wire. Are all
electrical wires point-to-point, or can they have multiple “ends?” Of
course my test gear is all set up to send tone down very different
wire types/connectors.
I guess I could also fire up the engine, observe the glowing light,
and yank one, the other, and then both of them and observe the
ignition light glow and note changes.
Can you tell I have no idea what I am doing? =)
I’m not looking to “fix” anything though, so much as learn what I am
looking at.–
–chuck goolsbee
65ots, 1E10715
arlington, wa, usa
