69 OTS
After many hours of painting, I am about to re assemble my IRS. I
know that sometimes the order of assembly of a group of related
components Must be done in a certain order. Other times, it is
just easier to do if an optimal order is followed (because some
things can get in the way of others).
After many hours of reading the various repair manuals the
following order of assembly seems to make sense to me.
Place rotors on diff output shafts
Attach calipers to diff
Attach handbrake calipers to brake calipers
Install diff to IRS Cage
Attach wishbones to mounting brackets
Attach driveshafts to differential output shaft
Install clamshells on outer drive shafts
Install hubs into hub carriers
Install hub carrier assemblies
Install radius arms
Install shocks
Any comments or suggestions?
Thanks,–
Glen - 69 OTS. Restoration documented at www.myjagsite.com
