In reply to a message from dtype sent Mon 7 Apr 2014:
dtype (we prefer to use names on this forum),
What series E-type are you referring to? It could impact the
answer.
There appears to be some opportunity for confusion in this
area, given the information I found when researching the
same topic a while ago. The Jaguar parts lists for Series 1
3.8, Series 1 4.2, and Series 2 engines all show C.5022 (1’’
Briggs). None of them reference a sealing washer. This is
consistent with the plug have a tapered thread. As I
understand it, the Briggs standard is a tapered thread, but
is an American standard, so I am rather surprised that
Jaguar would have use it instead of BSP tapered. Perhaps,
they had to use an existing north american block heater,
which already had this thread type. If the thread is indeed
a Briggs thread, you will need a Briggs tap. It has 11.5
TPI.
Interestingly, if you look at the XKs Unlimited catalog,
they show a plug C.32276, with a copper sealing washer
C.2296/16. This plug is quoted by many other vendors
(including in the UK where I believe you are located), but
for later XJ6 engines. It is always quoted with a copper
sealing washer, so I assume that the plug in this case has a
parallel pipe thread - possibly BSPP. Maybe the practice by
some engine rebuild shops is to replace the Briggs plug with
the parallel thread plug and sealing washer when they
rebuild an early engine?
So, if your plug had a sealing washer I would question
whether it is really a 1’’ Briggs thread. If not, you need to
find a 1’’ Briggs tap (good luck), or see what you can do
with a pick.
-David–
http://tinyurl.com/b4fdupp XK140MC OTS, S2 XKE OTS, XK8 OTS
Monterey CA, United States
