In reply to a message from cadjag sent Tue 30 Jun 2015:
Come on Carl, nice little holders for the sprockets, the cam chains
even stay on, 4 bolts there, after those cute little cam cover
bolts come off. Some head bolts, an exhaust nut or four, and some
oil banjo bolts. All you need is a two ton chain fall and it pops
right off.
What did you want~ a zipper?
I’ll admit its easier if you change the coolant a couple times a
decade.
None of these problems with a flat head, right?
Dave–
1969 BRG OTS
Skaneateles, NY, United States
In reply to a message from David Ahlers sent Tue 30 Jun 2015:
Dave:
Well, they did share one propensity! Busted studs!! Same
cause.
And, yeah, a flat head V8’s heads were not only much
lighter, even if iron and not alloy, the angle and reach
over the fenders/wings was much easier. And, to many of us,
no fenders/wings, even better.
But, I confess to never pulling a jaguar DOHC head!!!
Came close, but went in another direction…
Carl–
Carl Hutchins 1983 Jaguar XJ6 with LT1 and 1994 Jeep Grand
Walnut Creek, California, United States
I too remember the flatheads and stuck heads! The “youngsters” on this site may not believe this but I remember a friend whose late 30’s V8 had the Ford HC Denver aluminum heads and he actually drove the car with no nuts on the head studs trying to get the heads to break loose, to no avail! He ended up breaking up the heads with a hammer and chisel, no air chisels then. I can’t recall if that engine ever ran again, but as used engines were next to nothing to buy it wasn’t big deal. I’m sure that you remember going to the junk yard to buy a transmission, Fords went for $15 in the Detroit area, and if it looked like none of the gears were chipped it was a deal and guaranteed all the way to the junk yard gate! I still have a rod out of the 274 inch Merc that was in my 39 coupe that ventilated itself at the old Akron drag races. Those were the days and thanks for bringing back memories!
Bob
889076
Plymouth, MiOn Jul 1, 2015, at 11:40 AM, cadjag carl.hutchins1@sbcglobal.net wrote:
Dave:
cause.
In reply to a message from Robert Stevenson sent Wed 1 Jul 2015:
‘’ Fords went for $15 in the Detroit area, and if it
gate!’’
Bob, I remember needing an engine for my Pontiac one
time…so I just went and bought an old rusty but running
Chevy for $20, pulled out the 283 together with the 2-speed,
put the whole thing in the Pontiac and scrapped the rest.
Cheap motoring, Eh?–
Clive, '62 Coupe 860320
Ontario, Canada
Yep those were the days! On the other hand, while looking back “at the good old days”, I tend to forget that while I was building that full race flat head I was also working almost full time for $1.25 an hour at a gas station while going to high school!
Bob
889076
Plymouth, Mi.On Jul 1, 2015, at 9:28 PM, Clive Wilkinson clive.wilkinson@sympatico.ca wrote:
gate!‘’
Cheap motoring, Eh?
Ontario, Canada
In reply to a message from Robert Stevenson sent Thu 2 Jul 2015:
Yeah, and you could put a dollars worth of gas in the tank
on Friday night and you were good for the weekend.–
Yep those were the days! On the other hand, while looking back �at the good old days�, I tend to forget that while I was building that full race flat head I was also working almost full time for $1.25 an hour at a gas station while going to high school!
Mark 1E14988 67 OTS, 2002 VDP
Burke, VA, United States
Dang Bob, what did you do with all that money
pauls
Yep those were the days! On the other hand, while looking back =93at the =
good old days=94, I tend to forget that while I was building that full =
race flat head I was also working almost full time for $1.25 an hour at =
<<<<<<<<<<From: Robert Stevenson bobanddarl@comcast.net
Subject: Re: [E-Type] Leaded gas?
Just saved for the next 30 years and bought an E! In reality I poured it into the next project, 302 Jimmy in a 39 Chevy coupe. When the flat head blew at the Akron drags we had to go to the local junk yard to get a tow bar welded up so we could a tow get home! Gosh I’m glad that Carl keeps brings up things that jars my memories of how things were!
Bob
889076
Plymouth, Mi.On Jul 2, 2015, at 3:41 PM, Paul Spurlock jagdood@gmail.com wrote:
pauls
