Hi Jerry,
That’s an idea, but it defeats some of the features of my design. I wanted
some features that weren’t generally available, and wanted to be sure of the
quality of the components that were used. These are the features that I
included in its design:
� Uses the original points and condenser, so there are no modifications to
the distributor. You don’t even need to open it to install the ignition.
� Uses the original coil or a Sports coil, but with low points trigger
current so the points should never wear out or need adjustment. However,
the points still carry enough current to burn off any oil or oxide film.
� Connects to the three existing posts on the distributor and coil, so
installation is simple.
� Housed in a small die-cast aluminum enclosure with mounting ears. It’s
about the size of a cigarette pack, and mounts to the frame rail with wire
ties.
� Uses a 20A, 500V MOSFET for switching, with a high-speed 20A snubber
diode and a 125�C, 1000 volt capacitor. (Large safety margin)
� Output is over-voltage and over-current protected, using modern
Polyswitch, MOV and TVS surge suppressors.
� Has an electronic dwell-extender circuit, so the coil spends most of its
time charging, independent of the points setting. Dwell is independent of
the points gap, so the gap is largely irrelevant.
� Only powers the coil when the engine is running, even if the points are
closed. With the engine off you can listen to the radio or perform
electrical testing without burning out the coil or points.
� Has a switch on the side that instantaneously and conveniently
disconnects the electronics and connects the points back to the coil in
case of failure. You don’t need to try to re-install the points in the dark
by the side of the road as you would if a Pertronix failed. Just flip the
switch and your car is back to normal.
� Includes a rev limiter which uses sequential spark stealing when the
pre-set RPM limit is reached. The engine simply loses power at the redline
to save your engine even if your tach is inaccurate.
� Has an LED on the case which lights when the points are open, making
static timing easy and convenient.
I have already hand-build a couple for my own use, and they seem to work
fine, but I still need to address the S2 tach problem. Using the original
points allows you to revert back to your standard ignition system should
this one ever fail. Because of the switch it will never leave you stranded,
and being stranded is a big worry for me.
Mike Eck
'51 XK120 OTS, '62 3.8 MK2 MOD, '72 SIII E-Type 2+2
Jag-Lovers Picnic at www.jag-lovers.org/events/event_view.php3?id=326
Mike Eck,
How’s about letting your device work with either
Pertronix or points?
Jerry
