[E-Type] map light pic
Does anyone have a picture of the map light area?
Mine is missing and would like put it back in.
thanks john
71 series 2 2+2–
john sinclair
In reply to a message from 71 4.2 sent Thu 19 May 2011:
No picts but mine was missing as well. The remnants of the two
rivets were still there. I wouldn’t drill them out since I feared
going right through the dash pad. If you can’t re-rivet it back, I
just used some epoxy and glued the thing back on. It should last
another 50 years.–
thanks john
scott64FHC
danville, United States
I can grab a shot when I get home. Stay tuned.
–chuck goolsbee
65ots, 1E10715
bend, oregon, usa
Here’s my map light:
http://chuck.forest.net/jag/maplight/index.html
The lighting is not so great, sorry.
Mind you, I have no idea how “correct” this example is… goodness knows so much else on my car is wrong (long story) so I can not assume this is right.
Hope this helps.
–chuck goolsbee
65ots, 1E10715
bend, oregon, usa
In reply to a message from chuck goolsbee sent Thu 19 May 2011:
Thanks chuck and paul for the quick reply.
john–
Mind you, I have no idea how ‘‘correct’’ this example is… goodness knows so much else on my car is wrong (long story) so I can not assume this is right.
Hope this helps.
john sinclair
Chuck,
Interesting. Mine looks identical but has the old style bullet
connectors. I suspect yours has been modified but whoever did it was
skilled because it looks like the rivets have not been tampered with.
That’s a better connection IMO than the original.
pauls 67ots
this is right.
<<<<<<<<<<From: chuck goolsbee cg@goolsbee.org
Subject: Re: [E-Type] map light pic
A few years ago I purchased a replacement map light. What I got was
similar to the attached pic’s and at the time I though that this was
so poor that it must be the wrong part, so never tried to fit it.
Looks like I was wrong!On Fri, May 20, 2011 at 4:39 PM, paul spurlock jagdood@gmail.com wrote:
Chuck,
pauls 67ots
this is right.
Les…'68 S1.5 2+2
