Can someone tell me what the part is called that is mounted to the
heat shield and sits behind the three brake fluid bottles on a 69
OTS? Also, what does it do? Thanks Dennis–
Dennis Fesmire ‘69’ OTS
In reply to a message from Dennis F sent Mon 13 Nov 2006:
Xk’s unlimited, page 198, It’s name is the Brake/Clutch reservoir
shield. For the 196p with no power steering it’s part number
C18695 $83.39 and with A/C and power steering C30735 $95.16.
I would make one out of stainless steel before I buy one. The
insulation material is readily available.
Hope this helps.–
Brad
huntington valley, PA, United States
In reply to a message from smallguy sent Mon 13 Nov 2006:
A stainless steel cookie sheet from the kitchen supplies area of
WalMart would be a good source. A good aircraft-quality metal
snips from Sears to cut to size and a bench vice and hammer to make
the bends would finish out the project.–
Pete 70 XKE (193K) 88 XJ6 (233K) 88 XJ6 (217K) 60 Mini
Severna Park, Maryland, United States
You mean the a/c resistor? A green tube about 3" long? It is used to
control the speed of the a/c blower.
Mike Frank
Brad,
Isn’t there a resistor mounted on some of the later cars for the AC
on the heat shield? If so I wonder if this is what he is inquiring
about?
Cheers,
Lynn
Another option if the heat shield is needing replacement is to
consider John Farrell, his include a very authentic insulation
material as well. NAYYY
The
Hope this helps.
Brad
Cheers,
Lynn
Lynn G
73 2+2 (Pearle)
68 OTS (Emmy)
Boise, ID USA
In reply to a message from Lynn Gardner sent Mon 13 Nov 2006:
Thanks to all who responded.I should have described it better. It
was the A/C resistor.The terminal end broke off and I soldered it
back on, But I wasn’t sure what it was. My A/C is not hooked up
anyway. Thanks again to all, Dennis–
