[E-Type] Photo of fuel line " T" between ser.2 carbs
In reply to a message from PhilW sent Sat 16 Jun 2012:
Look at this ‘‘T’’ fitting on E-Bay Item number: 270918406408.–
Can anyone locate a photo of the plastic fuel line ‘‘T’’ on the
series 2 E? I found a damaged one, but it is black and I seem to
think they were white (or off white). I was trying to explain it to
a guy that works on obscure foreign cars and he thought there’s
something available like that.
Thanks,
Phil.
John Watertor 69 XKE Coupe
cedar rapids,Ia, United States
Phil,
There is a photo of the ‘‘T’’ on Page 12 of the JCNA E-Type
Series 2 Judge’s Guide that you can find online at the JCNA
web site. As you say, the T is white.
-David–
davidxk '56 XK-140 OTS, '69 XKE OTS , '98 XK8
Monterey CA, United States
Before you fit one to your car, I would ensure it is compatable
with ethanol fuel.–
Ralph, 1970 FHC, www.xkedata.com/cars/detail/?car=1R27295
Pine Beach, NJ, United States
Mine was black way back when I replaced it with a metal
one.Because it cracked and spewed gas all over the engine,
good thing it was caught as I pulled out of the garage…I
hate to think I would 've had to use my fire extinguisher
and have a burnt car…–
Benny 1968 4.2 S11/2 OTS
Old Bridge NJ, United States
In reply to a message from davidxk sent Sat 16 Jun 2012:
They were ALL white–same color (almost) as the fuel line. The JCNA
guide suggested is correct and this has been an item of interest in
JCNA–as such SNG Barratt is reproducing the ‘‘T’’ in the correct
shape and size with a very careful eye toward modern fuels. The big
advantage of using the original '‘T’'s is that bits of the ‘‘T’’ do not
break off and stop up the float valves as do the rubber tube with
steel '‘T’'s. The down side is that the correct ‘‘T’’ must be placed
in by pulling both carbs off the studs. The major failure of the
orig. '‘T’'s is that they were bent and forced in improperly. Without
disturbance they last as long as the orig. fuel lines!–
JCRC SE member JCNA Regional Director SE JCNA Auth. Desk
Columbia SC, United States
In reply to a message from George Camp sent Sun 17 Jun 2012:
Thanks, George.
I thought they had tiny rubber hoses on each end, but I mis-
remembered. I’ll have to check out SNG, if I can figure out what
it’s called in their catalogue.
Phil.–
PhilW
Virginville, Pa., United States
In reply to a message from PhilW sent Sun 17 Jun 2012:
Phil it is a new product–not here yet but soon-perhaps a call will
speed it up!–
