I couldn’t help but reply about all these comments regarding old tires and
speed ratings.
I have been in the tire business my entire life (third generation in the
business) so I have seen one or two.
This talk about using very old tires which I would consider anything over
about ten years old is a recipe for failure. Typical tread separation
conditions are preceeded by deep cracking in the shoulder area of the tire
and then when subjected to extreme conditions such as very hot or very fast
or both the tire will come apart. Sometimes preceding symptoms of a
separation are low speed wobble (car kind of wobbles and is felt at 10-15
mph). -
Tube failures are more common these days because the tubes available
through most sources are not very good quality. Buy the best you can get. -
Speed ratings mean the tire is capable of sustained speeds up to the
rating speed. It doesn’t necessarily mean that an H rated tire handles
better than an S rated tire because there are some cheapo brand H rated
tires that will not perform as well as a good quality S rated. Within a
given manufacturer, an H rated will be a better performance tire than an S
rated.
For higher speed ratings, especially when you see the same tire made in two
different ratings, ie: H & V rated versions of the same tire, the tire will
be basically the same, but there will be additional overlays usually nylon
cord over the belt layers to contain the tire at high speeds so the steel
belts will not delaminate with extreme centrifical force.
Speed ratings are as follows:
S = 112 MPH
T = 118
U = 124
H = 130
V = 150
W = 169
Y = 188
Z = OVER 150
(Quoted from the 1999 Bennett Garfield Tire Guide)
Burt Hoffmann
66 OTS______________________________________________________
Get Your Private, Free Email at http://www.hotmail.com
