My original fuel pump is long long out of service, and a
NAPA electronic has been on the car since I bought it. It
went south yesterday. This morning I went to NAPA and bought
a replacement, only to find literature in the package saying
it is only for negative ground use.
I would appreciate information form some of you guys on am
available electronic fuel pump that is OK with my positive
earth car.
Thanks
Bruce–
Bruce Harless, '64 S1 ots
In reply to a message from BruceHarless sent Sat 9 Oct 2010:
Check with British Parts Northwest. They stock a dual
polarity fuel pump.–
69 S2 2+2
Mission BC, Canada
Does anyone kave a pic of the “upgraded” fuel pump sold by SNG and probably
others that they can post? I’m curious to see what it looks like.----- Original Message ----
To: e-type@jag-lovers.org
Sent: Sun, October 10, 2010 10:15:55 AM
Subject: Re: [E-Type] replacement fuel pump
Bruce
Is your fuel pump inside the tank? I have a '63 and have ok
experience with a fuel pump assembly that SNG provides.
In reply to a message from stephan2828 sent Sun 10 Oct 2010:
Stephan, my extant fuel pump is (was) a NAPA electronic unit
that had replaced the very dead in-tank original. the local
NAPA store said they no longer carry that unit, and they had
nothing for a positive ground. I have located some on the
internet, including the Aircraft Spruce that Paul Spurlock
had referenced in a thread I found in the archives. WalBro
has an appropriate one, but it is ‘‘no longer available,’’ for
whatever reason. I’'m like Larry Kohler, would like to see
a pic of the SNG unit.
Going back to an internal fuel pump is not an issue for me,
other than cost right now. I’m just interested in a
replacement bolt up unit for a positive ground system, and
was hoping someone who is using on ecould tell me a source
for a known-to-be-workable unit.
What is the SNG unit that you have?
Thanks,
Bruce–
Stephan
earth car.
95 XJR, 69 E-Type ots ,07 Miata ,‘X’-type SUV
Sierra Madre Ca 91024, United States
Looks well thought out and well put together. The wires include
the bullets for plugging right in. The sock has a spring inside to
keep it from collapsing.–
1961 E-Type OTS
Still looking for a replacement fuel pump, and wonder if
anyone knows of a resource for rebuilding the original Lucas
FP-2 unit?
Bruce–
In reply to a message from BruceHarless sent Tue 12 Oct 2010:
You might check with Walt Osborn at Vintage Jag Works. He can
probably rebuild your old unit. http://www.vintagejag.com/index.html
The SNG photo looks just like the replacement I got from XKs
Unlimited a number of years back. The pressure was too high, so I
installed a good fuel pressure regulator. The pump failed after
two years. A '74 Vega fuel pump was pretty much a drop-in for the
guts of the pump in the XKs unit, was inexpensive, and has worked
fine for three+ years. I have converted my vehicle to negative
ground, though. The SNG/XKs unit will likely not work for your
positive ground vehicle,–
FP-2 unit?
Walt P 1964 E-type FHC, 1966 MGB, 1972 Triumph GT6
In reply to a message from WaltP sent Tue 12 Oct 2010:
Walt, thank you for the info – I will check with Vintage
tomorrow to see if that’s anything near viable for me. If
not, it looks as if the Walbro option is going to be my best
bet. I do appreciate your and others’ replies.
Bruce–
One fellow suggests taking your original pump to a
generator/alternator specialist to have it checked out and/or
repaired.
Polarity with the SNG pump isn’t an issue, by the way. It is
isolated from the car chassis and can be wired to accommodate
negative or positive ground.–
1961 E-Type OTS
repaired.
1961 E-Type OTS
