Does the foam padding on top of the radiator effect cooling at all? I have a brand new one from XK’s and I’m debating whether I want to put it on or not.
In reply to a message from Royal Lichter sent Sun 6 Jun 2010:
YES now I have to type more so this is taken–Royal Jaguar would
not have used it if it did not–but it does help esp if the car has
AC!–
Thanks
JCRC SE member JCNA Publications and Authenticity Desk
Columbia SC, United States
Thanks George. Thought that might be the case. What’s the best
adhesive to attach it with?
RoyalSent from my iPhone
AC!
Thanks
Royal!
On my 69 I took it off and found no difference even in high
heat driving.
I helps to have a good radiator system.–
Walter Schuster 78XJ6 FI Ser.II
Albuquerque/New Mexico, United States
I have been driving my 71 coupe for 25 years without it. However I
installed the missing foam recently and picked up an extra 4psi oil
pressure …51psi on cruise at 2000 rpm.( I have an oil cooler
mounted lower front of rad), no change in temp, though… mine
always runs in the white lower portion of the temp guage.
Overheating has never been a problem… recored rad and the twin
fan factory setup for th e Ser. 2 … life is good…–
'71 S2 OTS, 2R14073, Silver
mytype
Kelowna, B.C., Canada
Thank you for the input! I’m not having a cooling problem…however…any Jaguar owner wouldn’t mind an extra few degrees…LOL. No oil cooler on mine. My temp gauge usually runs directly in the middle, maybe a tick to the right. I do have the mike frank fans, too!
mytype
Royal!
heat driving.
