A quick question I hope. Recognizing problems with measuring cylinder compression (i.e.,
gauge error, importance of seal, effect of temperature), what is an acceptable range of values for
a 63 3.8 liter? I called a Jaguar dealership this morning who said that they didn’t carry specs on
cars that old. This is the same dealership with a 150 in the showroom. I suppose the car is safe
enough in the showroom, just don’t let the boys in back get there hands on it.
Thanks,
Kyle
cylinder compression (i.e., gauge error, importance of seal, effect of
temperature), what is an acceptable range of values for a 63 3.8 liter?
The official factory service manual cites 180 lbs. for the 3.8 E-Type. My
'64 FHC was just tested at having an even 150 lbs. for each cylinder and
the mechanic said this was acceptible for a 33-year-old E-Type. This may be
an idication, however, of the need for valve work some day.
Bob
180 pounds is original performance for a CR head that has not been milled
with stock 9 to 1 pistons. 150 even-all cylinders is ok for an 8:1
Head. Important thing is that readings are even. If they are even then
leave it alone.
Brian IzenbergOn Wed, 26 Nov 1997 17:38:34 -0500 “Robert J. Richardson” rrichardson@eurekanet.com writes: At 12:41 PM -0600 11/25/97, Chatman wrote:
of
liter?
My
and
may be
an idication, however, of the need for valve work some day.Bob
