Hi - I am wiring up switches now on center dash. 1967 sereies
1 fhc 4.2. My ignition switch has 3 spade connectors (1
double).
uh oh - wiring diagram shows 4 poles. Looks like I might have
wrong ignition switch. I’m not S 1.5 but all kinds of things
were changing anyway - did jag go to a 3 connector ignition
switch later? I am doing the delco alternator upgrade so might
just need one from the alternator skipping the voltage
regulator.
But with one needed from starter switch, ammeter and one to the
6 fusebox, it appesrs like I need a new switch.
I did not do the disassembly on my car and my old harness came
to me in a big plastic bag with no categorization. Could
anyone provide a picture of the ignition switch on their center
dash that shows which harness legs the white leads are from at
the switch and fusebox - right now I’m starting out and have a
ton of white leads some of which belong on the fusebox - anyone
have a pic tht shows the specific harness leg and where the
white leads go to? I’ve got to be careful here. thanks–
glennj - 67 S1 FHC
wake forest, NC, United States
In reply to a message from glennj sent Sun 16 Aug 2015:
Glenn, If you go the photo albums and search for ''ignition
switch ‘’…you might find something helpful.My cars are SII
and III…so of no help.–
double).
John M Holmes 1973 E Type SIII Supra 5Sp, 70 SII OTS 05XJ8L
Ontario, Canada
I sent you an email with some pics from my 3.8.
Chris–
If I can’t fix it, I’ll fix it so no one can !
Highgate Falls, Vermont, United States
