I removed all the vinyl coverings before the car went in for floor replacement etc. When
they came off, the outer material separated from the inner foam. On the back it says
Spradling Softside; I presume that this is not original.
I will clean them up and refit in the spring; any recommendations on a thin replacement foam
backing?
Also, what do you recommend for an adhesive that has good adhesion, but will allow the vinyl
to be removed without destroying the outer surface.
As always, thanks.–
Ian 1970 OTS
In reply to a message from Smeg999 sent Sun 5 Dec 2010:
I use the foam for auto headliners… it comes in different thickness–
Currently building 875880 OTS,
Gastonia, North Carolina, United States
