So, my gas filler compartment isn’t draining properly. I’ve searched and read many posts here in the forum and understand that the filler compartment drain tube drops down to a Y connection, joining a drain tube from the rear door, which I can’t find. And the resultant tube exits in a hole behind the left rear wheel in the quarter panel, which I found. Now, here’s my situation. There are two holes in the filler compartment (see photo). The odd-shaped one has no tube and drops down about 8" (checked with coat hanger) onto a metal surface of some kind. When I pour water into it, the water drains out of the shock absorber metal surround onto the ground.
The filler compartment round hole has a tube which drops down about a foot onto a metal surface of some kind (coat hanger) and also drains out of the shock absorber metal surround onto the ground. I tried the coat hanger in the normal exit hole behind the rear wheel, but it wouldn’t go even an inch. And there’s no water draining there.
I can’t see anything because of the gas tank. Anyone have an idea just where the water is going? Is it a problem?
