In keeping with the thread on AC wiring, the blower on
mine was inop throught the switch but would run when
wired direct to 12V. I ordered & replaced the fan
switch this weekend. I took exceptional care to
ascertain that the wiring went back exactly as it was.
I now have an operative blower, but only on high
speed. I suppose that at some time in her nearly 33
years, someone could have possibly connected tthe
switch improperly. Consulting the “BIBLE”, I found
the wiring schematic on page 397. However, I could
not make heads or tails of their color coding. Anyone
out there that could offer some assistance?
Thanks,
Earl Kiker
In reply to a message from Earl Kiker sent Mon 28 Apr 2003:
Earl, your problem might be with the fan speed resistor mounted
near the windshield washer pump just below the heater box. On my
74 I found that the A/C would only work on high speed. After
inspecting the original resistor, I found that the wire winding on
the resistor was broken resulting in a broken circuit. Once I
found a replacement resistor the A/C worked perfectly. The hard
part was finding a replacement resistor. My original resistor was
black in color. I could not find one of those. I located a used
resistor colored green. It worked but when in use it began to
smell like melting wires - so I quickly disconnected it. I later
found a resistor that was coated in a brown covering. This was
much better. I can’t remember now where I found the brown one but
it was at one of the usual suspects. Hope this helps.–
Harris (1974 Series III, sable, 4sp, A/C, wires)
Jacksonville, Florida, United States
Earl wrote <<<<<<<<<<<"…switch improperly. Consulting the “BIBLE”,
I found the wiring schematic on page 397. However, I could not make heads
or tails of their color coding. Anyone out there that could offer some
assistance? ">>>>>>>>>>>>>>>>>>>>.
Hi Earl, I had a spot of bother with my speed control resistor and I had
to rewire part of it. My note book shows the following info…I can’t vouch
for this being accurate as i am quite sure it was fiddled with before I did.
Front connection, brown/black, centre green, and rear connection light
blue.The full resistance is 9.6 ohms and the off-set centre is 1.6 ohms from
the light blue. If your fan speeds are not right then switch the G and U.
John M Holmes 1973 S III 2+2 Supra 5-Speed, Ontario.
