E Type Series III - Rear chassis bracing rod (tunnel connector pipe between engine and trans)
Over 35 years ago some mechanic working on my 1974 Series III E Type Roadster apparently decided this part was not important enough to reinstall and it is simply missing, along with the end bolts and washers. This is an odd part to need, and I have not found any source yet. I could presumably fabricate one, but if anyone has a spare of this assembly I would appreciate a picture and price. I described the part the way SNGB does, but it is the connector pipe between the tunnel sides that bolts into the tunnel with the bolts coming in from the footwells.
Thanks
Rod
Add images
You should reach out to Chuck @ Monocoque Metal Works - Monocoque Metalworks | Jaguar E-Type body panels and shell restoration
Thank you, Ralph. I am going to need some rear wheel arch repair panels from him anyway (and maybe more). I will give it a try.
Rod
