My manual doesn't reference the seat belt warning wiring in the wiring diagram. I want to disconnect it as it occasionally goes off even though the seat belt being used. The archives mention that is may be connected to the ignition circuit which I want to avoid compromising. Can someone advise me where to disconnect it? In don't mind not having the buzzer work at all.
In reply to a message from Weston Keyes sent Mon 1 Dec 2008:
For 1974, it feeds from a purple wire on the same fuseblock as
feeds the main light switch and ends at the purple/black wire which
looks to be tacked onto the ignition switch and steering lock as an
afterthought. I presume the latter is the earth return.–
dogdog
My manual doesn’t reference the seat belt warning wiring in the wiring =
diagram. I want to disconnect it as it occasionally goes off even though t=
he seat belt being used. The archives mention that is may be connected to t=
he ignition circuit which I want to avoid compromising. Can someone advise =
me where to disconnect it? In don’t mind not having the buzzer work at all.
Many thanks
<<<<<<<<<<From: Weston Keyes westonkeyes@hotmail.com
Subject: [E-Type] Series III seat belt warning disconnect question
In reply to a message from paul spurlock sent Mon 1 Dec 2008:
Thanks for posting that Paul - I have described the door buzzer
circuit and not the seat belt buzzer circuit as Weston asked for.–
dogdog
Wes, Seat Belt Warning system…see ROM 86.65.00. the wiring
diagram is shown here , and NOT in the wiring diagram.the
circuit is fed by W and N/Y.If you wish for a pic of this
then pm me.–
Hello Folks,
My manual doesn’t reference the seat belt warning wiring in the wiring diagram. I want to disconnect it as it occasionally goes off even though the seat belt being used. The archives mention that is may be connected to the ignition circuit which I want to avoid compromising. Can someone advise me where to disconnect it? In don’t mind not having the buzzer work at all.
Wes Keyes
York, Maine
John M Holmes 1973 E Type SIII Supra 5-Speed, 1970 SII OTS
Sarnia, Ontario, Canada
