[E-Type] SIII ATF oil recommendation
What is the recommended ATF oil to use when you have to
replace about one gallon of the ATF oil in the automatic
transmission ? I drained the oil, but must believe that the
remaining of the 9 liters must be in the converter. I have
no idea what’s in there in terms of brand or if it is
mineral or synthetic. Can I just refill/top up with the
best synthetic oil available ?
Thank you in advance … Ole–
Ole-XKE1974
In reply to a message from Ole-XKE1974 sent Thu 21 Jul 2011:
The fluid needs to be ‘‘Type F’’, not the more modern Dextron/Mercon.
The difference in the fluids is the coefficent of friction. The
Ford type has a better grab. If you transmission tends to slip,
putting in a different fluid will cause it to slip even more. There
is a mod where you put Ford Type in a GM400 to make it shift
firmer. Synthetic fluid will work if it meets this spec.–
Dick Maury , Rebuild Dept.- Coventry West, JCNA President
Lithonia, GA, United States
In reply to a message from Dick Maury sent Thu 21 Jul 2011:
Hi Dick,
thanks for the answer.
I looked at the Mobil website, where they state that their
synthetic oils mix with mineral types, but they didn’t have
that last detail that you provided. Thanks !
… Ole–
Ole-XKE1974
I have not looked so I am not sure anybody offers synthetic in Ford
spec fluid. Kind of specialized at this point.–
Ole,
The S3 maintenance guide also suggests ‘‘Type F’’ for the power
steering system.
I’d just pour the Type F down there and be done with it…The Borg
Warner M12 is an old slush box and I’d hate to see you spend extra
time and cash searching for a synthetic that won’t do anything
better than the Type F does. I’ve used Dextron in an old XJ-S with
the BW and it felt like a sledgehammer was doing the shifting in
that box.–
Matt 1973 OTS
