Is the Series III horn relay common to any other Jag model? Any aftermarket
equivalents, etc?
Thanks,
Dave
'73 2+2
equivalents, etc?
Thanks,
Dave
'73 2+2
Replace it with a Bosch.
Cheaper, more dependable (will last longer), and even waterproof!
What more can you ask of life?
LLoyd
equivalents, etc?Thanks,
Dave
'73 2+2Search the archives & forums - http://search.jag-lovers.org/
I believe they’re all 6RA Lucas relays. They should interchange without
difficulty.
If you feel the need to go generic, Pick up a Bosch relay, 30 amps should
be about the right rating. I can give you pin equivalents.
Mike Frank
equivalents, etc?
In reply to a message from Braun, David G. sent Tue 4 May 2004:
Dave,
The S1, SII, early SIII and early XJ6 all used the same horn relay.
The relay was changed later in the SII production but I think the
only difference is how it is sealed. Any of these realys should be
mechanically and pin interchangeable with no fuss. Or get a Bosch.
Richard Liggitt–
'70 E Roadster, '98 XK8 Roadster, '02 Mini Cooper
Good morning, Mike
I could use the pin equivalents if you have the time.
Thank you
Carlo
Yeah, I’m getting good at resurrecting decades-old threads
Yes but at least you’re searching the archives for answers first instead of asking a question that’s already been answered 100 times on the forum!
With Lucas relays, the W contacts are the windings. They are non-polarized. The C contacts are the points. For Bosch relays, 85 and 86 are the windings. Some relays have a diode, and this will be marked on the case. In that case, the proper polarity will need to be observed for the windings. But most of them are non-polarized. 30 is the common point, and 87 is the normally open point. 87a is the normally closed point. See:
