At 10.11 1997-11-29 -0500, you wrote:
In a message dated 97-11-29 04:21:11 EST, you write:
<< t 07:33 AM 11/29/97 +1300, Mark Farnham wrote:
I found that my Etype just wouldn’t run properly on our 96 unleaded. It was
ok until it got hot then it used to pink like a skeletin in a tin box. >>When I lived in Houston the local jag engine guru would tell you to use 8:1
to avoid spark knock. It would get over 100 degrees for days at a time.
Despite thicker radiator core, accessory fan, the water temp often went to
200 C .
Well, that's HOT! Even more than the Finnish sauna ;-)
Things are different here in Seattle. But I just rebuilt the motor
again with 8:1, and on a 90 degree day had a trace of rattle on a hill.
Hope these were Fs...
What
was the octane available in the US in the '60s compared to now ? I think
different ratings are used now. In 1970 I used Sunoco 260 on my Z-28 Camaro
with 11.25 :1 without much rattle- even went to 12:1 on rebuild . Either the
Jag head characteristics are way poorer or the gas was way better thenDoug
Sorry Doug, couldn't resist...
cYa,
sin~
