…I think you are narrowing it down to the diaphranm
LLoyd
Now occurs everywhere, simultaneously. But it doesn't have to be
experienced the moment it happens. Every now that ever was is still exactly
when it was, when it was now. Then, in terms of perception, is nothing more
than all the nows that are no longer now. Thus, the difference between now and then is when.
–The Waystoppers Users’ Manual----- Original Message -----
To: e-type@jag-lovers.org
Sent: Monday, November 2, 2009 12:40:17 PM GMT -08:00 US/Canada Pacific
Subject: Re: [E-Type] Stalling problem… help!
In reply to a message from Jaguarpete sent Mon 2 Nov 2009:
Thanks to all for the responses so far (Andrys, John, Jack
and Pete)
A few more observations –
Air filter off. I start the car with the choke all the way
out, no problems. As I rev the engine, I can see the
pistons going up and down in both of the carbs. When I rev
it pretty aggressively (up to maybe 2800 RPM) I can see the
secondary butterfly valves open, though only a tiny amount
At this point everything seems normal.
However, when I start to ease the choke in, the idle speed
starts to drop slightly (as it should) but when I try to rev
the engine, the car stalls.
As an experiment, I start the car (with choke all the way
out) and hold the engine at 2000 RPM using the pedal. I
then start to slowly push in the choke. The engine dies
once the choke reaches about halfway in.
At this point, I do NOT think it is a throttle linkage
problem. I also visually inspected/ wiggled all the hoses
and vacuum lines, and all of them appear to be ok.
The car was fine, then it sat for about a week, and now
suddenly it has this stalling problem.
Does this sound like a gasket/ diaphram issue? Fuel mixture
too rich/ lean? Help!
Thanks!
Jon
Here are the symptoms – Cold starting is fine with choke
all the way out. Idles fine, no problems. But, as soon as
I push the choke in even halfway, it stalls. This happens
even if the car is warmed up (e.g. the water temp gauge in
the middle range…)
1969 4.2L convertible
San Francisco, CA, United States
