Faced with stubborn old IRS radius arm mounts, I devised a
very simple method to remove them.
made a tool out of 1/4’’ x 4’’ scrap steel plate.
Angle ground a U shape that exactly matches the INNER STEEL
BUSH of the large IRS bush.
push the steel plate over the mount,from the front, so it is
resting on the bush.
This leaves a small space between the chassis leg, and the
steel plate tool.
gently hammer 2 small cold chisels either side, between tool
‘‘legs’’ and chassis leg.
The bush has nowhere else to go but down, as the steel tool
then bears down upon the inner steel bush ring.
It popped right off.
This idea is so simple and effective, surely someone else
has done it ?
took me 30min to make the tool, but the U shape must be
exact enough to clear the mounting post, but still ride on
the inner steel ring, you have about 1mm tolerance.
You need an old or new bush to make the drawing accurate
enough imo.
got the idea from rock-splitting, where gads are hammered in
patiently, and let the pressure & time do the work.
I can post a pic if anyone wants to see–
Tony
