My temp gauge has stopped working and I’m trying to trace the problem. I
suspect it’s the temp sender but I’m not sure. Is there an easy way to test
this? Using an ohm meter perhaps?
Thanks,
Ed
Thanks,
Ed
Ed,
I tested mine by taking the wire off the sender and grounding it to the
block. If the gauge is working this will cause the needle to peg on the hot
side.
Tim-----Original Message-----
Sent: Wednesday, 26 April, 2000 10:25 AM
To: XKE Lovers
Subject: [E-Type] Temp Sender problem
Thanks,
Ed
I believe, if you remove the wire at the sender end, short it to
ground and the gage goes to hot, the sender is shot.
zat rat? (Southern for “is that correct?”
LLoyd -studying southern for future vacation trips-
Ed Scripps wrote:>
this? Using an ohm meter perhaps?Thanks,
Ed
Can I add to Ed’s message about the temp sender. Is there supposed to be
voltage going into the sender ( the wire from the gauge to the sender)?
Or is that supposed to be a grounded wire.?-----Original Message-----
To: XKE Lovers e-type@jag-lovers.org
Date: Wednesday, April 26, 2000 10:48 AM
test
Ed
Eugene,
It is the ground wire.
Sent: Wednesday, 26 April, 2000 2:50 PM
To: e-type@jag-lovers.org
Subject: Re: [E-Type] Temp Sender problem
test
Ed
If it only has one wire, and most of them do, it goes to the negative
side of the instrument.
As the module heats up the resistance changes reducing the resistance
puts more current through the gauge.
If you put a VM on the wire you will see voltage as it is being fed
through the gauge.
ground the wire and the gauge should go to max.
The usual problem is that the element opens up and the gauge can not see
the ground circuit.–
http://www.mail-abuse.org *
Del.& from address e=k. *
http://robertstech.com/gallery/page13.htm
Notice: Spelling mistrakes left in for people who
need to correct others to make their life fulfilled.
