Mine used to do that. I assumed some part of the linkage was expanding as the engine heated up and was causing one of the throttle plates not to close fully. When mine did that I could drop the idle to spec by very quickly blipping the throttle. It still does it occasionally but not very often, not often enough that I am going to try to fix it.
As was mentioned make sure the throttle plates are all opening and closing together and that all are closing completely when the accelerator linkage is at idle. I’ve set mine up with just a slight amount of play in the bell cranks at idle, that is when you step on the gas the linkage moves ever so slightly before the slack is taken up and the throttle plate spindles begin to rotate.
Things to check for (some more likely than others):
Make sure there is no binding anywhere in the linkage, from the accelerator pedal to the spindles.
Check to make sure the linkage is not contacting the frame rail under the carbs. Can happen if the motor mounts are compressed from age. Usually this happens at wide open throttle and causes much excitement when it happens in traffic.
Could be grit or some kind of deposits on the carb piston rim or inside the vacuum bells. Clean with carb cleaner and be sure to mate the same piston and bell when reassembling. DO NOT use an abrasive (like emery paper) here.
Make sure the jet is centered and the piston falls freely. An off center jet will cause the needle to bind when the piston drop.
Make sure when the engine is hot and the choke is off that you have a little clearance between the fast idle lever and the adjusting screw.
Make sure each piston damper that screws into the top of the bell is in good order, check for a bent shaft.
With the engine hot and the engine not running open the throttles by hand by moving the linkage that controls all three carbs. Watch the individual linkages at each carb. You want the spindles to all start rotating at exactly the same instant.
When the engine is hot and the idle is high try closing each throttle plate individually by pushing on the bell crank attached to that carbs spindle and see if the idle drops. Seems like that would tell you if the problem is in a single carb.
There are probably other things to check as well but these few come immediately to mind.
John
