What is a good SII 2+2 four speed worth with the shift lever?
What about a good used flywheel, manual pedal box and driveshaft?
Thanks
Robert–
Jaguar Performance :AJ6, Paramount, 5 speeds, etc…
www.TheDrivenMan.com, United States
See http://classicjaguar.com/evalue.html for car values.
Reply-To: e-type@jag-lovers.org
Subject: [E-Type] What is a good SII 2+2 four speed worth?
Date: Fri, 28 Apr 2006 21:58:54 +0200
Thanks
Robert
In reply to a message from Randy Olson sent Sat 29 Apr 2006:
Robert!
This list does not aggree with the NADA value list if you
compare it, its much too low.
Also there are exceptions as having a one owner car, well
maintained from day one.
Walter
69E ser.II 2+2--
Walter Schuster 78XJ6LFI Ser.II, 69Eser.II 2+2
Albuquerque/New Mexico, United States
In reply to a message from TheDrivenMan sent Fri 28 Apr 2006:
Hmmmmm… People seem to think you’re selling a car, rather than
parts. The four speed will generally fetch around $500, unless
it’s just been rebuilt, in which case more like $1000-1500,
depending on verifiabity of a correct rebuild. The flywheel and
driveshaft are probably worth not much more than it would cost the
ship them somewhere, maybe $50-100 each tops. The pedal box might
be worth a couple hundred, especially if you can find someone doing
a RHD to LHD conversion. E-Bay is a good reference for what the
high end of the scale is worth. Search the completed auctions, and
you should be able to find most/all of those parts.–
Santa Cruz, CA, United States
In reply to a message from Ray Livingston sent Sat 29 Apr 2006:
I agree with Ray on everything, except the box. The 2+2 box
has an extended rear housing and shaft and since many of
these cars came with automatic transmissions, there are not
as many manual gearboxes around. I had a hard time finding
a decent (not rebuilt) 2+2 box for less than $1000. Good luck,–
Kent
