Kirk,
Look at it this way, it’s a far less painful chore than changing the heater
pipes. It’s a good idea to remove the dash top first to improve access a
bit. Drop the instrument panel down and remove the relay and bracket from
the rectangular opening. Now the fun begins. Fish around under the cowl
with your hand until you locate the screen washer. If you’re lucky or have
very small hands and arms, you can push the tubing over the end of the
washer and the barbs will retain it. Otherwise, you can unscrew the wing
nuts securing the screen washer to the cowl and remove it. Don’t drop the
wing nut or lock washer. If you do, they are lost forever. This is a good
time to replace the tubing as well.
Next, feed the tubing up through the wing nut and lockwasher and then
through the hole in the cowl. It will be easy to attach the screen washer
to the tubing since everything is accessable. Push the screen washer back
into the hole and locate the nut and lockwasher strung on the tubing. Push
them up to the washer and secure. Everything else is, as the manual says,
the reverse of disassembly.
You will have scrapes and perhaps a cut or two on your hand and forearm by
the time you finish. Have a beer to lessen the pain.
Allan Jones-----Original Message-----
From: owner-e-type@jag-lovers.org [mailto:owner-e-type@jag-lovers.org]On
Behalf Of David Kerr
Sent: Tuesday, October 14, 2003 3:03 PM
To: e-type@jag-lovers.org
Subject: Re: [E-Type] Windscreen washers
In reply to a message from Kirk Phillips sent Tue 14 Oct 2003:
Kirk,
I think you are looking at a partial dismantling of the dash. Even
with my car in its rebuilding stage the washer tubing is a right
b*****d. My hands were red roar getting in to the jets.
When I eventually got the tubing on I managed to get some very
small cable ties around the jets and tie them off using long nose
pliers.
I think this type of job would suit a surgeon who does key hole
surgery.
Dave
'61 OTS
I tried the washers on my '68 FHC and discovered that the tubing to
the drivers side had come loose from the jet and was dumping the
water down my pants leg. Does anyone know how to access the jet to
reconnect the tubing? I just can’t see how to get to them without
some major dismantling of the dash. Any advice would be
appreciated!
David Kerr
Pershore, United Kingdom
