so do all early FHC xk120’s have the early map drawer and not the bronze slides?
Up to what chassis number???
thanks!
thanks!
Hi George,
Yes, there were two early map drawers.
The first was 7" wide. The second was 7-3/16" wide.
What is your chassis number?
You definitely need to get the factory parts catalogues on CD. There was a main one covering all 120s, a FHC supplement and a DHC supplement.
This is from the FHC supplement.
I do have the factory parts manual, original and copy, and the FHC supplement but none of those describe the parts that the drawer slide in…a sheet metal box or the brass slides.
Maybe the picture shows it…but I am150 miles from the books right now.
I do like the real books better than a CD.
so, I’ll assume that the sheet metal box and the ball catches are correct since my chassis number is lower than. 679179…the upper limit of the first type.
