All –
Back in February – just before the covid thing blew up – I bought this second driver car so I could experience the XK120-thing now rather than waiting years down the road due to incremental progress on my other '120 OTS. This is car 670236. Beverly Hills Car Club purchase. From about March/ April 1950:
As I do some light maintenance on this neglected driver, I’ve noticed some anomalies that don’t jive with my later car (670898 from October/ November of 1950), the parts book and my old copy of XK120 Explored. Thought I’d share a few finds with comments invited.
First, the rear door shut panels are all secured to the body with countersunk screws – not spot-welded threaded studs on the back side like other steel cars. Was this something that carried over for a little while from alloy-cars?
Second, the stud-less cylinder head appears to not have any numbers stamped where the engine number repeats itself. I think I once read that early cars didn’t have their heads stamped with the engine number. Is this true?
Third, the wind screen frames have a peg on their top corners instead of a threaded hole where the frames meet that center post top cap. I’m not seeing any reference to this either in my books but it sure looks factory to me.
Here’s a window frame from my late '50 OTS showing the difference:
Securing the frames to the top cap with countersunk screws was a better idea as, in my case, the bottom frame rubber had degraded so much one of the windscreen halves had settled slightly where it meets the center post. Wouldn’t have happened were it secured with the countersunk screws or a fresh rubber seal (something I’m doing now). Nice to know Jaguar was thinking of us 70+ years on with the countersunk screws.
Fourth, the radiator grills really do have ribbed sections:
Fifth, the steering rod on this early steel car does not take any of the replacement pin assemblies commonly sold for these cars. I’d have to do some serious reaming in order to get them to fit. The original pins pictured lying on their sides simply had rubber on them – no outer metal sleeve. No matter, I’ll just turn replacements of acetal/ delrin in lieu of the original rubber and press fit them in in lieu of reaming the holes to take modern replacements. Notice one of the pins (from the driver’s side – LHD) has its washer noticeably larger than the one from the passenger side.
Sixth, the windscreen wiper. It appears to be date-stamped March 1950 (3 50) but has a mounting that I haven’t seen on my other car or in books. This one has/had 2BA studs with flats on top threaded into the wiper body. On top of the flats were round rubbers glued to these flats and then duplicate flats/ studs that in turn screw to bracket on the car. Not sure how I’ll go about fixing this yet.
Finally, I’m kicking myself for not saving the old fuel tank. Wish I’d taken a picture as it’s since been trashed. Does anyone have a picture of what the ones on the alloy cars look like? I have a feeling mine was a carryover from those cars as it was much more angular (best way to describe it) and had the recessed sending unit section soldered – as opposed to stamped in. Regardless, it was pretty beat on the underside and leaked as well.
